show msdp mesh-group
show msdp [mesh-group {detail} | {mesh-group} mesh-group-name] {vr vrname}
Description
This command displays configuration information about MSDP mesh-groups.
Syntax Description
detail Displays detailed information about MSDP mesh-groups.
mesh-group-name Specifies the name of the MSDP mesh-group. The character string can be a maximum of 31 characters.
vrname Specifies the name of the virtual router to which this command applies. If a name is not specified, it is extracted from the current CLI context.
Default
N/A.
Usage Guidelines
Use this command to display configuration information about MSDP mesh-groups, as follows:
The following command displays the peer count for a mesh-group:
The following is sample output from this command:
MeshGroupName                     PeerCount
external                          0
internal                          0
msdp_mesh                         4
The following command displays detailed information about a mesh-group called "msdp_mesh":
show msdp mesh-group "msdp_mesh"
Mesh Group Name      : msdp_mesh Num of Peers : 4
Peers                : 54.172.168.97   55.0.0.83       124.56.78.90
221.160.90.228
This command was first available in ExtremeXOS 12.0.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.1.1 Licensing Guide document.
